the internal speakers on my fx802 have stopped working, and before sending it for repair, i'd like to check their connection as it is more likely a cable that w ent loose than both speakers dying at the same time.
are they any service manuals available? it seems like there's just one screw to remove in order to remove the tray between the keyboard and the lcd, and then get access to the speakers, however i'd rather not mess things up, and more detailed information than what sony seem to provide on the website would be helpful.
