Hi all!
I have a lot of vhs made whit my old analogic camcorder.
Can I use my VAIO desktop as analogic/digital converter? I have tried to connect my videorecorder to my PC, but the PC screen became black. What was my mistake?
Many thanks
rox
What model is your Vaio?
it's a PCV-2246
Rox
Go to www.vaio-link.com and enter your serial number at the download area. The model number will appear in the dropdown list at the top of the page. Repost with that number.
OK, done!
The model is PCV-RS502
Thanks
Rox
Good news!
Yes you can connect your camera or video to the computer. You can connect to the video in port and audio in ports and simply use gigapocket to record the video (select direct input as the input source).
After doing that you can use Click to DVD to produce your DVD.
