Hello,
I´ve a vaio desktop PC PCV-RX5130 and I´ve the newly problem, when I play WOW then the PC starts a alert sound after 10 minutes an the power button starts to flash. But I have no error message, so I don´t know whats the problem and this case is untreated in the instruction guide.
Need Help!!!
Your computer is probably overheating.
Turn off the computer, remove the case and make sure that the graphics card and/or processor fans are running. Also, remove any fluff and dust by using a small vacuum cleaner nozzle or air duster. Be careful when cleaning that you don't make the fans spin too fast and damage them.
mine also did that
