I spilt some lager on my VAIMo and whenever i himt the b key it types bm. What should i do, its just happened. DO you think if it dries overneight it may bem alrimght
MMmmm shameful waste of good lager:smileysad:
It should be ok by the morning. If you have a can of compressed air you could use that to blast some of the moisture away.
The real problem is if the keyboard suddenly takes a fancy for lager after this. :smileygrin:
I agree with TR a bit of compressed air to clean it should work. If it doesn't, then go to Maplins and get a keyboard cleaner.
