Hi!
Should I put the Akku away when the Akku is complete charged from the NB´s FE31 M and N11/S? Or is it for nothing to put it away when I work with the normal supply?
Thx Werner
You know what I mean? Sry my E is very very bad
Akku is a battery in English, but yes I understand your question.
You can do that, but remember to drain the battery once a month.
ok thanks
I mean that the battery is "severed" from the power supply when the battery is in the NB, for example MAC has the function. Then for the battery is it not good to charge and to discharge it.
Some NB can separt it automatically when it is full loaded!
And does the both NB´s this feature? I hope this was correct!
Thanks
Anybody knows this?
Hi ExxonWerner,
The process is automatic in Vaio Notebooks. The circuitry prevents overcharging and the charge rate reduces to almost nothibg when your battery is fully charged.
You can download MobileMeter which will show you the charging rate and you will see it reduces to almost nothing when your battery is fully charged.
Same here Thal
The Mac does stop charging when done too
The battery charge and consumption rate and does not register on my Vaio..
Thanks!
