Hi guys! I've had my Sony Vaio NR11Z/S for about 18 months. I've just got myself a wireless router, ever since setting it up I am having trouble with my left click?
Could the fact that I am now using a wireless connection be affecting it? I did find another post online from a guy with exactly the same prob, but am now having trouble finding it again.
Any ideas?
Many thanks,
D~
Most left-click problems are caused by a hardware fault in the button itself.
One way to see if it is software related and anything to do with wifi is to disable the wireless connection temporarily and seeing if the problem goes.
Alternatively you could try a System Restore to a time before you had the problem or - as a last resort - carry out a full system recovery from your recovery discs or hard drive recovery.
Sorry I cannot help with your wireless router problem
(I have a Linksys with same model Vio and only problem
I have is my battery is almost useless after 20 months)
Do you know where to get a new battery for the VGN NR11Z,
I beleive the part number is VGP-BPS9/B but cannot find in
on any spares website.
Good luck with the Router.
BMDSWD
Hi BMDSWD and welcome.
Generally speaking it is better to start a new thread for unrelated problems, but I suggest that you contact Support via the link at the top of this page.
You will of course find non Sony batteries offered for sale but there is no guarantee that they will work...
