Pretty much like it says above, is it possible to add scrolling two touch gestures (yeah same as on the Macbooks) to the CW2 Vaio in addition to the zoom?
Would just be nice to have in addition to the standard way of scrolling, and otherwise I am very happy with the way the touchpad is working. Especially like the tap to click functionality of it (much more than Apples version of clicks 😛 ).
Cheers.
It's possible if it is a Synaptics touchpad in the CW2, but if you are unlucky it's a ALPS touchpad. If it's a synaptics, just search on google for two finger scroll and you will have it. If it is a ALPS, call the Sony support and begg on your knees that they put preasure on ALPS to come out with new drivers that support two finger scroll.
