I opened my computer,
and I know now how large is the power Supply on the RS 102 (and certainly on 104..)
so it's 15 cm Wide, 8,6 high, as all other ATX power supply,
but it's only 10 cm deep...
no matter if there was enough space, but there is only 5 cm free space behind the power supply.
And the wire get out from the back of the power supply...
Normal ATX power supply are 14 cm deep
do you know a not so deep power supply pleeeeeease :smileygrin:
I think the main problem with ugrading the ATX power box in most Sony PCs is that they're non-standard, so you'd have to search somewhere to see if there's any second hand ones around.
It might be worth trying
http://www.sonyspareparts.com/
There is always the possibility that SONY themselves do a suitable power supply in another desktop. This company may be able to advise you, based upon your needs.
Try this one
http://www.pcpowercooling.com/products/power_supplies/highperformance/turbocools/index_hp_1u.htm
Only200mm * 100mm * 40mm
Dimensions shown at
http://www.pcpowercooling.com/products/power_supplies/dimensions/index.htm
but it's too short, I mean,
it musst be 15cm wide X 8,6 cm heigh.
Only the deepth can be changed!
So I found the format:
it's not an ATX power supply,
but a PS3 Power Supply I need...
Thanks for the information cody.
if you have any name of PS3 power supply, dont hesite, tell it to me :smileygrin:
