i just want to ask if the display resolution reaches only till 1378x768 (if i remember correct) on my sony vaio.
My model is SVF1521S6E and i recently change my operating system to win7 pro service pack1.
I dont know if the problem is windows 7 and i cant remember if the problem was and with win 8.1.
I have the old HDD with the 8.1 win but before make the change to check it about i want an answer.
All in the desktop are big for me (icons,sites on explorer etc).So i wanna know if there is a solution.
Thanks
