hi
i am new to this but wondered if anyone can help with BD error 'aacs out od date' eror
Hi leo450,
welcome to club VAIO..
some vaio owners have been able to update the AACS key whist other have not..
The guide below was supplied by Sony and hopefully will help you please let us know?
First the Corel Web page must be added as a Trusted Website in the Internet Explorer software.
1.Click the Start button, and then click Internet Explorer .
2.In the Internet Explorer window, click the Tools button.
3.On the Tools menu, click Internet Options .
4.In the Internet Options window, click the Security tab.
5.On the Security tab, under Select a zone to view or change the security settings , click the Trusted sites icon, and then click the Sites button.
6.In the Trusted sites window, under Add this website to the zone , type the Web site URL address (for example http://www.sony.com ), click to clear the check from the box next to Require server verification for all sites in this zone , and then click the Add button.
NOTE: The box next to Require server verification for all sites in this zone must be clear before the Add button is clicked or an error message will appear.
7.In the Trusted sites window, click the Close button.
8.In the Internet Options window, click the OK button.
In the Internet Explorer window, click the X in the upper-right corner to close the window
Then proceed as follows:
1.Insert the Blu-ray Disc (BD) movie into the Blu-ray Disc (BD) drive.
2.Click the Start button, click All Programs , click InterVideo WinDVD , and then click InterVideo WinDVD BD for VAIO .
3.At the AACS Key has expired error message, click Yes.
4.On the Corel DRM system on Vista Web page, click the Next button.
5.On the Corel Account Web page, if you already have a Corel account, use your existing user name and password to continue. If you do not have an account, in the New User field, click to select Personal and then click the Submit button.
NOTE: New Users will have to enter the necessary contact information to complete the COREL Account registration and, once all required information has been provided, click the Submit button.
6.On the Patch download Web page, click the link to begin the patch download.
NOTE: The word "here " is the link.
7.In the File Download window, click the Save button, and save the file to the Desktop .
8.In the WinDVD BD for VAIO window, click the X in the upper-right corner to close the window.
9.On the Desktop , double-click the just downloaded WinDVD .exe file.
10.In the Do you want to run this software prompt, click the Run button.
11.At the Update Module Setup prompt, click the OK button.
12.Restart the computer
13.Click the Start button, click All Programs , click InterVideo WinDVD , and then click InterVideo WinDVD BD for VAIO .
14.At the AACS Key has expired error message, click Yes .
15.On the Corel DRM system on Vista Web page, click the Next button.
16.On the Corel Account Web page, use your user name and password to continue.
17.At the AACS key update is now finished prompt, click the OK button.
Hello,
the problem is that when I want to open the coral-page, appears a messege: programming problem. It is impossible to open the web site.
Hope you can help me!!!
Thank you in advance.
Hi der_antichrist,
Have you tried contacting Corel to see if there is a problem with their site.?
You will need to register or sign in to ask Corel support a question, use this link: Sign In / Create Account
Have you ensured that you have the latest version of Win DVD for Vaio installed on your system.?
