Hello,
I have a vaio notebook A417M (but with 1,2Go RAM) and I work under Flash 8.0 Pro.
But, since a few weeks, I have a trouble : Flash freeze totally my computer, and i can't do nothing else....
I have uninstalled and reinstalled many times, but I have these same trouble... Can somebody here have problems or troubles under Flash 8 with an A417M or a vaio notebooks? Is there a solution or patches for A417M notebooks ???
It's very annoying, and Flash is my work tool. If I can work correctly in my Sony Vaio, I can keep this computer no longer...
Thanks in advance for your help !
sorry I don't have any solution for you. tke it easy
When does it freeze?
I think the only thing you can do is speak to Macromedia/Adobe, as Sony won't help you as it's a 3rd party piece of software.
Quand-est ce que ca arret a marcher?
Je pense que la seulle chose que tu peut faire est contacter Macromedia/Adobe car Sony aide pas avec les logicels 3eme partie
