I just get a A317M. I installed XP Pro with SP2 but now, I can't get the 'extra' buttons working (sound level, brightness, S, cd eject).
I have the restore CD, I download everything from vaio-link, but nothing seems to work.
Is there anybody to help me ?
Thanks,
Yves
Yes I did ....
I'm tired of this, I sell this PC ....
Thanks a lot for your answers....
LOL just to make a remark...its amazing how easily VAIO customers are willing to sell their PCs from the first time they find a difficulty...especially in software...:smileygrin:
You're right there, people won't try and sort things out, they rush to eBay.....
Which is sad.
Yes I did ....
Sony should start doing some thinking...but then again..does ANYONE from Sony EVER read ANY of these posts???
Have VAIO Link had a look at it?
Ooops, sorry, but I don't understand your last answer.....
Ok, I'll try once more .... Because I like this notebook. If only I could find that 'utils.exe' to make my special keys work !!!
In itself, the notebook is great but it's very frustrating that I can't use all of it's functiunalities because sony don't provide enought support .....
If someone could give me a download link to my missing files, I would be happy to keep my A317M.
Thanks a lot
Yves
Sur ton cd de restauration il y a un dossier VAIO Applications, tu l'ouvres et ensuite tu ouvres le dossiers Applications;là tu ouvres le dossier Utils Installer 2 et tu clic sur le setup;ensuite tu reviens dans le dossier Applications et ouvres le dossier Utils Installer 3 et pareil tu clic sur le setup. C'est les 2 fichiers nécessaires pour les réglages du son,de la lumiére, bref des touches fonctions.
Salut
Salut,
Merci pour ta réponse, mais j'ai essayé ça aussi.
J'ai finalement downloadé les fichiers du A217 ....
Ca a fonctioné sauf le mode 'auto' pour la luminosité.
De toutes façons, le portable est vendu.
Comme je l'ai expliqué dans une autre réponse, ce portable m'a posé des problèmes depuis le début.
Quand ce n'était pas la carte son, c'était les drivers ATAPI, ou le graveur DVD qui n'a commencé à accepter quelques médias qu'après avoir flashé avec un firmware LiteOn !!!
J'ai donc acheté un acer .... nettement moins beau, écran de moindre qualité .... mais j'ai installé un XP Pro SP2 sans AUCUN problème .... et toutes les fonctions spécifiques du laptop (y compris les hotkeys) fonctionnent SANS PROBLEME.
Merci à tous pour les réponses.
De rien,
Ma mere pense a acheter un Acer aussi, elle n'a pas une grande bujet pour un Sony!
