I Need the driver but cant find it anywhere...
And i dont know what to do with the driver pack which on on vaio link... what should i do. does anyone know a link?
Thanks
Matty
The Driver of your network card is in the driver package.:smileyraised_eyebrow:
But it has no installer file. You must start the Hardware Manager.
there you see all devices which are installed (or not correct) of your VAIO.
Rightclick on the device, then click update and select the folder with the driver.
But if you see a installer file in the folder of the driver, then use it.
