I have had my A197XP for a couple of months and am devastated by the fact that it overheats and freezes when I do cpu intensive work (especially playing games...not that it's work but you know what I mean
Can anyone offer any advice? Sounds like a major design flaw.
Stuart
Make sure there's nothing blocking the vents like cables or your clothes
clean the air vents with compressed air, they may be clogged with dust..tho unlikely after such a short time of use
place a checker piece, at each corner underneath the laptop which elevates the laptop slightly and provides better air circulation and cooling
get a conventional fan and blast it at full power into the air vents providing u dont mind the extra noise
The measures above dropped my idle running temp from 41 degrees to 31..
Furthermore, u can buy a laptop cooling base, which sits below your laptop extracting warm air, theyre known to work very well if u dont mind the extra bagage!
Antec sell a good one avaliable in both europe and the US for like 23 british pounds
http://www.antec.com/us/pro_details_notebookcooler.php?ProdID=75004
Heres 2 others aswell with a review of each
http://www.tomshardware.com/firstlook/20040322/index.html
cooling is always gonna be a problem for powerful laptops, tho theoretically, sony should have designed a more efficient cooling system, you are not the only one with this problem..
They look like pretty good cooling solutions.
