i'm sorry but i don't speak english...
i'm italian...
I have problems with the bluetooth of the my model a197vp.
I have install the update sp2. Before there aren't the bluespace driver. My os was perfect.
I use the sp2 bt driver.
The problem is that when i start my bluetooth via switch in the event registry i see:
warning: bthusb - id event 18
"Windows cannot store Bluetooth link keys on the local transceiver because it cannot determine whether proper security is enabled for the device".
Someone can help please?
There's one solution for this event?
In all the web i don't have found information...
up
Check www.vaio-link.com for updates.
There may be a conflict with bluespace and the bluetooth software of sp2 try uninstalling the one you do not wish to use:smileywink:
Ditch Bluespace.
I uninstalled bluespace from my 197 once i'd installed sp2 and it all works fine. Just a shame there's STILL no headset profile.
Glad you got it sorted.
