Hi all,
The scroll feature on my touchpad on my A115B no longer works. I recently selected the task tray program 'Touch Pad' not to load on start up and I think that this is the problem. I cannot find this program to re-activate and do not know it's actual name to do a search.
Any advise on this would be welcome!
Thanks,
Stewart.
You should be able to change it under 'Mouse' in the control panel.
Most touch pads are made by a company called Synaptics as i think they invented the touch pad.
But you should be able to renable by opening control pannel, then selecting mouse (in classic view) or printer and other hardware (in category view)
