Hi all,
i've changed my old Graphic card (Geforce 2 mx) on my PCV RX1 for a non-GT 6600.
I need to connect it at a molex, and i tried yesterday :
- After reeboot, mouse stopped to work
- Power supply got hot quickly
Of course, i've deconnect my Molex cable to avoid explosion :smileygrin:
What can i do ? Can we change power supply on this computer ?
Thx
It might be hard to change as it's a non-standard power supply
Can i Change case + Power supply with all my actual components ?
I'd like to keep my Vaio case, but if it's the only solution....
Hopefully you could, but it might not screw in well to the board.
Mmmh, give it no possibility, to use the Power supply extern.
I think you need only a normal Power supply and cables they are long enough to reaching the PC components.
True, a VAIO with an external Power supply are not really nice. But I think that is a possibility. (tell me, If I'm wrong)
Euuuugh that would be ugly
True, but it's the only possibility:smileysad:
