Hi, I recently upgraded my VAIO VGN-AR21S from XP to Windows 7 succesfully. My internal Memory Stick, that I used to upload photo's from my Sony Cyber Shot camera, is not recognised anymore. The drive letter, corresponding to the Memory Stick, does not appear anymore in Windows Explorer. What can I do to fix this issue, where can I find a new driver for this very useful Memory Stick.
Thanks for your replies. Best rgrds, Jan
Hi Jan
I know you must have upgraded a while ago now but I wonder if you can help me with my upgrade.
I did a clean install of Windows 7 from XP on my VGN-AR21S but as a result have no sound.
(I've also modified the playback settings with no success).
Can you remember whish drivers etc you installed and in which order when you did your upgrade?
I'm uncertain which of the Vista drivers and instllation files I sould use with little support available for Windows 7 on this laptop.
I'm happy to reinstall and start from scratch but don't know what to install and when in terms of the vaio software and drivers.
Many thanks
James
Dear James and Jan,
