Non esiste alcun supporto per sistemi linux?
Non riesco ad esempio a regolare la luminosità dello schermo...o a far funzionare i tasti rapidi da tastiera su Ubuntu 8.04. C'è almeno qualche sito di riferimento a cui ricorrere?
Grazie
Paolo
the solutions that are in launchpad (bug 305672) doesn't work for me. And YES! i use ubuntu and gnome-power-management doesn't work 😕
I didn't read the whole bug report yet,
but would you please so kind to post the output of the already named method in a terminal:
acpi_listen
battery BAT0 00000080 00000001
Only battery event is detected. Nothing more.
Ok, you should report a bug with:
sony z series FN-keys --> ACPI events not detected.
You shouldn't try brightness solutions before this function is recognized with acpi_listen
or doesn the command
xevin a terminal directly write some other events?
