ciao a tutti...come al solito la sfiga con i computer mi perseguita...ho appena comprato(stamattina) un sony vaio FZ21M e con mio dispiacere ho notato che nel leggere i cd da dei problemi,ovvero:inserendo un cd musicale(originale)non lo legge e lo da come vuoto!!!
mica sapete cosa posso fare per risolvere il problema senza ricorrere all'assistenza?
Stesso problema con il mio fz21z, ma a me nn riconosce proprio l unita F:
Ti darò notizie sulla possibile soluzione al + presto
Contattato la sony, queste le possibili procedure.
Spero te la cavi cn l inglese
Firstly, please ensure that you have downloaded all available updates for your computer at www.vaio-link.com
1) Right Click on "Computer", click properties and click "Device Manager". This will open the Device Manager.
2) Double Click "CD/DVD - ROM drives" and then double click on your Optical Disk Drive
3) Click on the driver tab & click the uninstall button.
4) Please restart your computer twice.
5) You can try to do a BIOS reset once the computer restarts.
To do this, press the "F2" key several times once you can see the Vaio logo prompted on screen and press "F9" and "Enter" and after that, press "F10" and "Enter".
Has this solved the issue? If not, please try a system restore. You can use System Restore to remove any system changes
that were made since the last time you remember your computer working correctly. System Restore does not affect your personal data files
(such as Word documents, browsing history, drawings, favorites, or email) so you won't lose changes made to these files.
Firstly, restart your computer and keep tapping the F8 key as it boots up. Please select the "Safe Mode" option and press enter.
1) Click Start.
2) Point to All Programs.
3) Point to Accessories.
4) Point to System Tools.
5) Click System Restore.
6) Follow the instructions on the wizard. Please restore the computer back to a date when you know that it was working correctly.
If a system restore does not resolve the issue, then the last option available would be a complete recovery of your system. This will wipe all data on the hard drive and restore your computer back to it's factory settings, so please ensure to backup your important data first.
1) Please ensure that you have all data on your hard drive backed up externally. A full recovery
will restore the VAIO's factory default settings and wipe all data on the hard drive
2) Please restart your computer and tap the "F10" key as the VAIO starts up. This will launch the VAIO Recovery Utility. If your VAIO has Windows Vista installed please press the Enter key now. If your unit has not a Recovery partition, then you can use the Recovery DVDs supplied with your unit.
3) Please follow the onscreen instructions to begin the recovery. Ensure that you select the
complete recovery option when prompted.
Facci sapere, buona fortuna
anche a me comunque l'unità E a volte non la riconosce
grazie mille...ho provato a seguire la procedura descritta nella tua risposta ma nn cambia niente...all'assistenza mi hanno detto che è un difetto di fabbrica e che risolveranno il problema a breve...meno male!
