Me he comprado 2 portatiles, uno para mi novia y otro para mi los dos tienen el Windows Vista. He instalado el Nero 7.10.1.0 en los 2 y solo funciona en el mio, en el de mi novia siempre sale que hay algun error. Perdonad por el texto tan grande, es un fichero Log, a ver si me podeis comentar algo. Gracias de antemano.
1C83-7221-10E5-477X-405C-3740-****
Windows XP 6.0
IA32
WinAspi: -
NT-SPTI used
Nero Version: 7.10.1.0
Internal Version: 7, 10, 1, 0
Recorder:
Adapter driver:
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM:
Adapter driver:
=== Scsi-Device-Map ===
=== CDRom-Device-Map ===
MATSHITA DVD-RAM UJ-850S F: CdRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 2037MB (2086464kB)
Free physical memory: 1073MB (1099500kB)
Memory in use : 47 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
14.9.2007
CD-ROM (ISO)
0:36:19 #1 Text 0 File SCSIPTICommands.cpp, Line 424
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
0:36:19 #2 Text 0 File Isodoc.cpp, Line 6666
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
0:36:19 #3 Text 0 File Burncd.cpp, Line 3196
Protección contra insuf. datos activado
0:36:19 #4 ISO9660GEN -11 File Geniso.cpp, Line 3343
First writeable address = 0 (0x00000000)
0:36:19 #5 Text 0 File Burncd.cpp, Line 3508
Turn on Disc-At-Once, using CD-R/RW media
0:36:19 #6 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 359844 ( 79:59.69)
Last address to be written: 51096 ( 11:23.21)
0:36:19 #7 Text 0 File DlgWaitCD.cpp, Line 319
Write in overburning mode: NO (enabled: CD)
0:36:19 #8 Text 0 File DlgWaitCD.cpp, Line 2972
Recorder: MATSHITA DVD-RAM UJ-850S;
CDR code: 00 97 15 17; OSJ entry from: Ritek Co.
ATIP Data:
Special Info [hex] 1: C0 00 90, 2: 61 0F 11 (LI 97:15.17), 3: 4F 3B 46 (LO 79:59.70)
Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
0:36:19 #9 Text 0 File DlgWaitCD.cpp, Line 493
>>> Protocol of DlgWaitCD activities: <<<<br/> =========================================
0:36:19 #10 Text 0 File ThreadedTransferInterface.cpp, Line 793
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 51097 (51097) = #51097/11:21.22
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 51097 blocks [F: MATSHITA DVD-RAM UJ-850S]
0:36:19 #11 Text 0 File ThreadedTransferInterface.cpp, Line 995
Prepare [F: MATSHITA DVD-RAM UJ-850S] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 104953856, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
-150 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
-150 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 51097 | 0 | 0x00
51097 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
0:36:19 #12 Text 0 File SCSIPTICommands.cpp, Line 215
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
0:36:19 #13 Text 0 File Burncd.cpp, Line 4294
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
0:36:19 #14 Phase 24 File dlgbrnst.cpp, Line 1762
Caching of files started
0:36:19 #15 Text 0 File Burncd.cpp, Line 4413
Cache writing successful.
0:36:19 #16 Phase 25 File dlgbrnst.cpp, Line 1762
Caching of files completed
0:36:19 #17 Phase 36 File dlgbrnst.cpp, Line 1762
Burn process started at 16x (2.400 KB/s)
0:36:19 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
0:36:19 #19 Text 0 File MMC.cpp, Line 17687
StartDAO : CD-Text - Off
0:36:19 #20 Text 0 File MMC.cpp, Line 22363
Set BUFE: Buffer underrun protection -> ON
0:36:19 #21 Text 0 File MMC.cpp, Line 17915
CueData, Len=32
41 00 00 14 00 00 00 00
41 01 00 10 00 00 00 00
41 01 01 10 00 00 02 00
41 aa 01 14 00 0b 17 16
0:36:19 #22 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
0:36:20 #23 Text 0 File Cdrdrv.cpp, Line 1352
00:36:20.918 - F: MATSHITA DVD-RAM UJ-850S : Queue again later
0:36:29 #24 SPTI -1040 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1040)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x10
Sense Qual: 0x00
CDB Data: 0x2A 00 FF FF FF 6A 00 00 20 00 00 00
Sense Area: 0xF1 00 03 FF FF CF 24 0A 00 13 00 00 10
Buffer x07b27940: Len x10000
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0:36:29 #25 CDR -1040 File Writer.cpp, Line 303
Illegal block size for command
0:36:29 #26 Phase 38 File dlgbrnst.cpp, Line 1762
Burn process failed at 16x (2.400 KB/s)
0:36:29 #27 Text 0 File SCSIPTICommands.cpp, Line 261
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
0:36:33 #28 Text 0 File Cdrdrv.cpp, Line 11185
DriveLocker: UnLockVolume completed
0:36:33 #29 Text 0 File SCSIPTICommands.cpp, Line 424
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon
En mi Vaio me venia preinstalado Roxio, otro software para la grabación. ¿Has probado con este?
Probaste a desistalar los programas de grabacion que trae de por si el portatil, lo normal es que nero no se lleve Bien con roxio, lo raro es que funcione en uno y en otro no, si no es eso y todavia no paso el periodo de devolucion, corre a devolverlo, te ahorraras el tiempo de reparacion.
espero que tengas suerte.
