I cant make the Camera Capture Utility to work on my Vaio. I have already downloaded the new drivers, but it still displays the message "no input". Can anybody help?
many thanks
What model do you have?
XP or Vista?
What drivers have you downloaded? How have you installed these drivers?
I have the very exact problem.
Vaio VGN-TZ25FN
Windows Vista
Reinstalled original drivers and everyone that I can get from the web for the Ricoh webcam.
No luck...
Hi tob145.
I presume you have installed the original VCP-VCC7 driver (SODCAM-12938500-US.EXE) from here: -
http://esupport.sony.com/LA/perl/swu-list.pl?mdl=VGNTZ25FN
What camera capture software was originally installed on your Vaio? Have you reinstalled this also? There are a lot of Sony Applications on that page also but some applications are not available for download.
I downloaded the SODCAM-12938500-US.EXE driver (just for the Spanish version of the website you noted: http://esupport.sony.com/LA/perl/swu-list.pl?mdl=VGNTZ25FN&LOC=3). That is the one originally installed according Sony. I have reinstalled Vaio Camera Capture Utility and Vaio Camera Utility. I don't know what else to do.
Some months ago I had the same problem after a Windows Vista update (don´t know which one). I tried installing a lot of drivers for other TZ models, and eventually the camera worked again.
Now the problem arised after an update too, but I tried everything --I formatted and reinstalled Windows, etc.-- and the cam is still not recognized in the Device Manager, the VCCU shows "NO INPUT".
I don't think is a hardware issue, because last time the problem was solved with a new driver installation. I tried to reinstall all the drivers, original and new ones, and nothing happens.
Thanks in advance for any clue.
