+1(844)-539-9831 STR-DN1080 and Music center wifi problems
I recently bought a STR-DN1080 and overall I'm very happy with it. However I am having trouble connecting to it with the Music Centre app. It will connect fine using Bluetooth, and I used the app to set up the 1080's wifi connection to our
Althougth you conect to wifi is necesary the bluetooth connection is ON in boths .
But if both are connected for bluetooth for audio connection it’s necesary disconect before bluetooth connection for connect to Wifi.
“If your audio device and smartphone are connected via a BLUETOOTH connection, disconnect the BLUETOOTH connection on the smartphone.”
How conect by wifi
“ Outline of connection
Even if connecting with a Wi-Fi network, a BLUETOOTH connection is required.
If you want to connect your audio device to a Wi-Fi network using Music Center / SongPal, make the Wi-Fi network settings via BLUETOOTH communications.
If you are using iOS 13.0 or later, permit access to the Bluetooth from [Settings] - [Music Center] on the iPhone.”
https://vssupport.sony.net/en_ww/help/basic02_2.html
Questions & Answers STR-1080
https://www.sony.com/electronics/support/audio-components-receivers-amplifiers/str-dn1080/faqs
Music Center App how connect
It’ better if both items are update the last firmware and de Music Center app. wiil be updated last version.
https://www.sony.com/electronics/support/audio-components-receivers-amplifiers/str-dn1080/downloads
