x
profile.country.LT.title
aivaras123-
Explorer
XE7005 youtube cast
Hello. I have a 55XE7005, and when I am cast from phone youtube, everything works fine, but when i press stop casting from phone, tv restarts for once. So I am wondering it is normal? Maybe someone have same model, and can check this? Thank you
Tags (1)
4 REPLIES 4
profile.country.GB.title
Sean_Mc
Moderator
Hi there,
Have you checked that your TV has the latest firmware? You can see more details on how to perform this here.
Let me know how you get on.
Best wishes,
Sean Mc
aivaras123-
Explorer
Hello, thank you. :slight_smile: yes, I know how to check SW, and already checked, its the lastest SW. I don't know if its normal or not, because if i start casting Youtube from phone app, it works good. If I want to stop casting, and press "Back" or "Home" on remote, the tv doesn't restart and behave like it should (in my opinion), but if i press "Stop casting" from phone app, the tv restarts (illumination LED blinks for once, and "SONY" logo appears).
Thank you for answer.
The_Black_Rose
Specialist
Hi Aivaras123- ,
Have you attempted to soft reset the TV as explained here: https://bit.ly/2DVxVVV ?
Cheers,
The_Black_Rose
aivaras123-
Explorer
Hello, your post is for Android televisions. This is Linux.
