43xe7093
Two questions:
1. It does not seem to have Bluetooth. I have a Panasonic soundstage connected via the HDMI Arc. Is it possible somehow to connect my Bluetooth headphones via the soundstage in order to hear the sound from the TV or do I need some kind of external Bluetooth receiver (any recommendations?)
2. Is it possible to install Kodi and Plex apps? Or any other apps for that matter (is there an app store?) since the ones that come with it are pretty useless to me other than Netflix.
I do have an Android box that I can plug into one of the HDMI ports but would prefer the software option if available somehow.
HI Aston,
Are you thinking of buying this TV, or do you already have it?
It might be best getting in touch with the support team for advice here.
Cheers,
Sean Mc
Already have the TV.
Main concern at the moment is how to use my bluetooth headphones with it.
Not sure what kind of bluetooth adapter I need to buy (assuming the TV doesn't have bluetooth built-in, but hidden behind a service menu or something?)
I've decided to return this dreadful television.
I have ordered a brand new 43xd8077 for a pound more (no idea where they got a brand new 2016 TV from), which is a far better TV so all good now - I hope.
