Hi trying to play latest COD game on xbox in 3d with HX903
Just get 2 identical pictures on screen taking 1/2 screen each
What do I need to do settings wise to get 3D display?
Andy
Hey andy
I *think* from memory, whilst you have the side by side images up, you need to press the TV sync menu button at the top of your remote and call up the TV's options menu. From there, there is a 3D sub menu and you can select the type of 3D input, which in this case is side by side. The 3D button itelf may just toggle 3D on and off so you actually need to get into the menu to adjust the format. Unfortunately I don;t (yet) have a 3D TV at home so can't write down detailed steps.
As there are several different flavours of 3D ( side by side, frame sequential etc ), some devices lke sky boxes and seemingly 360 aren't great at broadcasting what type of 3D they are outputting so that the TV can adjust automatically.
What do you think of the new COD game? To be honest I was a little disappointed to be honest. Just didn't seem as refined as MW2
Thanks
