Working hours of Sony KDL50W805B
SOLVED
profile.country.GR.title
stavrosthess
Explorer
I would like to ask how I can find the working hours of a Sony KDL50W805B.
I tried (i+)+(5)+(Volume Up)+(Power) and Self Check (i+)+(5)+(Volume Down)+(Power). I see the menus, but I couldn't find working hours.
Is there anything else that I can do?
Thank you in advance.
1 ACCEPTED SOLUTION
Accepted Solutions
stavrosthess
Explorer
I mean usage hours of TV. But I found it
From Remote
Press (I+)
5
Volume Down
Power
Gets you into the diagnostics screen which shows the hours.
The bottom left 5 numbers are the hours
Next 5 are boot count
and last 5 are the lcd panel hours.
3 REPLIES 3
profile.country.GB.title
jumpsuit
Expert
Hi @stavrosthess and welcome to the Community :slight_smile:
Can you explain what you mean by 'working hours'
and what are you trying to do?
Thanks
stavrosthess
Explorer
From Remote
Press (I+)
5
Volume Down
Power
jumpsuit
Expert
Hi again :slight_smile:
Glad you managed to sort it :slight_smile:
