I have some problem to connect to a wireless n network with my KDL-46NX723.
When I change to only n in the router the tv will connect and all will work fine. But when I start the tv the next day the tv says it is connected but cant get access to the network anymore.
If i change the router to g all will work fine.
If I change the router to g/n (both g and n) the tv have access to the network but it will be slow (<1mb/s).
My router is a ASUS RT-N56U but I have also tested with an Apple extreme (v2).
Firmware on tv: PKG4.017EUA
Any ideas?
Message was edited by: Hjaunn
Added firmware
I will test another router to see if that will solve the problem.
I've used that TalkTalk router it isn't the best, its free but it is a low end model, weak cpu and wifi range is poor. I replaced it with a better router with external antenna, about £60 so mid range and resolved my issues.
