Bravia KDL-40NX713
I have followed instructions to set up a wireless internet connection on the tv.
I get the following.........................
Wireless Connection OK
Local Access Failed
Internet Access Failed
I have tried some basic troubleshooting such as restarting my wireless router to no avail.
Does anyone know what I need to do to get a wireless internet connection working.
Thanks
Finally fixed it ! BT had stored another security key.
have you tried turning off the firewall?
Unfortunately have exactly the same problem. Rebooting everything hasn't helped. Nor has disabling the firewall.
Did you resolve your issue? Any help appreciated.
Message was edited by: wizzym
Glad You solved it.
Regards
Damac
People, if you have your SSID hidden, then unhide it. This seems to fix the issue. However, it is a security concern which Sony needs to resolve in the next firmware.
Looks like Sony has fixed the bug with hidden SSID. My 22EX320 now connects to my router even when SSID broadcast is switched off. This firmware was released 3 day ago for 22EX320.
Hi, How do you add CAPITALS within the SSIDusingthe remote? Am i missing something.My SSID is hidden and is a mixture of lowercase and Capitals. Help me please!!!
I don't know about your Model but on the 22EX320, one of the coloured buttons (maybe blue but I can't remember for sure) switches between uppercase, lowercase, numbers and special characters.
