My two-month-old KDL-32WD756 TV suddenly lost contact with the home wireless network. No settings had been changed, and the router is still communicating with other devices. A check on the network status, after searching, gives the following error report:
Wireless device on TV: Not accessible
Local access: Failed
Internet access: Failed
Does the first line of this report suggest a fault with the TV?
Dear Manolo
Many thanks indeed for your prompt and very helpful advice. In the end it was not needed because the problem cured itself. Two days after reporting the fault, the network status suddenly changed from 'Wireless device on TV: Not accessible' to 'Wireless device on TV: Found'. No parameters or settings had been changed, so the cause will forever remain a mystery. Let's hope it doesn't happen again.
Best wishes from Ray.
Hello again Manolo
It just occurred to me that during this time we had a 20-minute power cut due to bad weather. It seems possible that this caused a re-setting of parameters. The advice might be: if it doesn't work, switch it off at the mains and switch it back on again!!
Ray
Settings > System Settings > Set-up > Network > Built-in Wi-Fi? Is [On] or [Off]?
If Wireless is "On"... Try a Reset (anyway, try also a Router Reset): Settings > System Settings > Customer Support > Factory Settings*
* Resets all settings to factory settings. After completing this process, the initial set-up screen is displayed. Note: Be sure not to turn the TV off during this period (it takes about 30 seconds) or press any buttons.
Manolo
Dear Manolo
"Let's hope it doesn't happen again"
Me too...
Manolo
All is possible, why not? TV has rebooted... By "bad weather" but has Rebooted...
Manolo
Any long term fix? Or anything I can do to avoid hitting this again? It was really annoying to have to go through the factory reset and I hope I do not have to do it again!
Hi there
Could a simple reboot of TV work instead of factory reset? If it happens again, switching the TV off from the wall for 2 minutes and try again.
I am also facing issue as above one. But after factory reset and switch tv off from main plug did not work for me...Can you please guide me .My TV model is KLV 43W772E..
Hello Sony,
I too have this same message and we have NetFlix button built into my SONY remote and it no longer works (yes, we continued paying after trial subscription) and we tried re-booting everything (modem, tv, cable box, etc.) and ours still says "not accessible". I was on the phone with Direct TV for an hour and they said they re-booted everything on their end. We have had multiple storms over the months.
Finally, I do not have a Factory Reset button anywhere in my Settings.
Any into will be helpful???
Thanks,
Gina
