can i connect my laptop to my kdl 40ex720 wireless with a uwa-br100? where can i find it, in Romania is not availeble for months.
you cannot connect your laptop using the dongle, only the tv, if you wish to stream music, video,and photo content you can do this via DLNA, but it you want to use the tv as a monitor then depending on laptop you can connect with HDMI or DVI cable.
