I am using my Samsung Galaxy S3 to connect to my TV using wi-fi direct, when I try to send a movie to the TV it says on my mobile that the file cannot be sent. Any suggestions about this? I can connect to my S3 using wi-fi direct no problem but when I try to send a movie, I just can't send it. Perhaps this has something to do with my S3 and I can't use it properly?
Message was edited by: Antyonee
Hi, what do you mean when you say 'send it'? If you are trying to copy the movie to the TV, no, you cannot do this. The TV does not have the storage to be able to receive a file like that.
You can install an app, such as BubbleUPNP to stream a movie to the TV from your phone.
I just want to stream it yes, the application you mentioned, I have no idea on how to use it all.
