Hi, i am trying to use the 'wi-fi direct' mode.
i have a wi fi dongle , screen shows 'connect from your device'
i go to laptop; bravia shows, i push connect , says pin required, (explaining that 8 numeral pin will be on tv or on paperwork with it)
i have searched tv, box and all leaflets and cant find anything saying pin,
I have phoned sony help, but they said use WEP code, okay that worked but it changes everytime, it takes 10 minutes to find it and enter it, surely there is a way i could locate this pin ?
Hopefully someone will be able to help.
Thanks,
Hi Moe, this is an older thread. If you need assistance with your BRAVIA, I would advise you to get in touch with Sony Support directly. You can contact them via this contact form.
