This TV does not emit DTS 5.1 sound to a receiver when playing an MKV file from USB.
It clearly states that it is doing so on th eTV screen, but it is not.
When will this be fixed, are Sony aware of this problem?
Hi there ToonPatriot
Unfortunately Sony are not aware of the problem, because the TV is doing exactly what it is designed to do. Ill attempt to explain:
According to the Supported File Formats : HERE and specifically MKV (see below):
You will note that it say DTS-Core. See pic below:
As you can see, DTS-Core only supports 2 channel audio upto the max bitrate as stated in the pic. When a file is encoded with DTS, it has two parts DTS-Core + DTS-HD. Hence the TV will only process and playback the DTS-Core bit.
Hope that explains things
I was always under the impression that DTS core was still 5.1 - And it in fact come up DTS SURROUND on the screen. But only emits stereo and nt surround as it says on screen.
(AC3 (Dolby) works fine though)
It also says DTS core supports up to 6.1?
And why would a £1200 tv not pass dts (5.1) through to a receiver!?
Just looking back at past posts - we touched on this late last year
Unfortunately Im not an audio expert - So I have limited understanding on this whole area.
From what I understand is that the 6.1ch at 48khz was the old DVD standard (I think - DTS-ES). The 48khz is the sampling rate, of which is lower than the high-res (DTS-HDMA) of which blurays support, hence lower quality, therefore more channels can be supported within the given limits.
DTS is an audio codec that is "layered". What I mean by that is you start of with the bare basics (DTS-Core) and then you add other layers ontop of it all.
Unsure on the audio pass-through at the moment.
Well Customer support kept on trying to blame my receiver (despite having no problem accepting any form of DTS or Dolby from any other source) and I must have been told to factory reset everything I own numerous times!
Is there anybody on here who can speak for Sony?
All I want is to not have to plug my laptop in every time I want to watch a movie. I don't want any sound to be processed by the TV, just go to the amp via the TV.
And even though it says DTS Surround on the TV, only a stereo signal is received by a receiver. So frustrating!!
Hi there
I have requested that your query be escalated and hopefully get a detailed reponse on why and is there a solution. Please ensure that you have the correct contact details under your account.
If you could update this thread once you receive an answer, as it may be helpful to others.
I have replied to Sony tech support with my number an best time to call..
I am pessimistic however as last time they just got me to restore my Receiver to factory settings (Despite it having no trouble accepting any form of DTS (even HDMA) from any other source.
ToonPatriot
Are you connecting your receiver using HDMI ARC or optical cable? I've read that DTS is always converted to 2ch PCM when connected via optical. Is the same problem using HDMI connection? I'm going to buy 5.1 receiver in near future, in this case it seems that external DLNA/USB player is needed to pass through DTS (and lossless TrueHD DTS-HD) tracks.
First, HDMI ARC givs only 2 channel.
These TVs supports DTS 5.1 (I believe that it is not really true) but not Sony. <<Foreign language link removed by moderator>>
