I have recently purchased a new PS5 and need to upgrade my tv to optimise experience.
The maximum size i can fit for my mancave is 32/34 inch set.
Will Sony be putting out a range of smaller sets for HDMI 2.1, 4k 120hz and HDR in the coming months/year?
My question is should i just hold off or will the range of tvs grow?
Myself I'm sticking with my 43" 4k 60fps TV just because I think true 4k60 will be the better option this gen with best graphical fidelity. 8k and 4k120 imo are going to be supported by sacrificing visual aspects well, at least until ps5 pro maybe?
Plus that's what I'm limited to by using the psvr passthrough anyway as it doesn't support the higher data required.
It's not easy to find TVs that small in size with all the bells and whistles for 4K gaming. You may be able to get a monitor in that size, but TVs tend to be bigger unless they're just Full HD.
The available models from Sony: XH90/92 start from 55"
Win_88
