What type of 3D glasses do I need for the Sony KD-55X9005B?
Hi there
According to your TVs specifications HERE - your TV is active 3D, therefore you will need the TDG-BT500A 3D Glasses.
cheers, do you know what type of smart remote i would require?
Hi there
Smart remote? Your TV should come with a remote control and the touchpad remote control.
However if you are looking for a more universal remote - I like the Harmony range from Logitech - https://www.logitech.com/en-gb/harmony-remotes
what type of batteries would i require for the 3d glasses and is there any links you can provide for me to buy somewhere?
Hi there
The TDG-BT400A and TDG-BT500A 3D Glasses use a CR2025 Lithium Manganese Dioxide battery - as described on page 6 of the reference manual : HERE
