Hi.
How can I install my webcam on my Sony DL 22 internet TV, Mic. works OK, but how can I install software so I can use it on Skype Video and all !!
As it is ,the TV responds to a Skype call but I need to go to another room to action it, Any help would be great.
Thank you & Regards
Martin p
the Sony CMU-BR100 is the one you need for your tv but in order for this to work you will also need to update the firmware too.
could you expand on the question a little more plz, ie the model of tv and what "webcam" your referring to?, anything other than the skype camera designed for sony tv's wont work.
The tv is a 22" KDL-22ex320 have been trying to use an, it works ,standard type webcam, are you suggesting I use a specific type of webcam ? For this TV model, please advise
Regards Martin p
Thank you for your help.
Regards
Message was edited by: -Cass-
Edited for personal details
Message was edited by: linedancer111
