I would like to use a web cam with above tele.. For Skype
But the Sony web cam on its own is £89.00
Can I just plug a normal ( none Sony) web cam to the tele. And use for Skype
Please help me to find a cheaper solution.
Thank you very much indeed
sorry, its a no can do, the only one that you can use is the Sony one.
