Hi guys,
I just bought a UWA-BR100 USB WiFi Adapter for my Bravia KDL-32EX401 TV. It is listed as compatible on http://www.sony.co.uk/product/tpa-other-tv-accessories/uwa-br100/#pageType=Compatibles
However, when I plug the WiFi Adapter into my TV, I don't see any options for configuration - it doesn't seem to recognize the fact that I've plugged in the adapter. I've looked all through the settings options.
I have turned the TV on and off, unplugged the TV from the mains power, restored Factory Settings and made sure I was on the latest firmware.
Is there something I'm missing?
Cheers,
Mark.
I spoke with Sony directly, and it seems the KDL-32EX401 is not compatible with the UWA-BR100, and the web page is incorrect.
The web team have been notified of the error.
I shall be returning the WiFi Adapter.
Cheers,
Mark.
Bad luck Markcub. Have you considered HomePlugs? You should have better luck using these.
