USING MY TV TO SHOW PHOTOGRAPHS.
I HAVE JUST BOUGHT A SONY BRAVIA TV WHICH I NOW FIND REQUIRES A DONGLE IN ORDER TO BE PART OF MY HOME PC NETWORK. WILL A NETGEAR ADAPTOR,CURRENTLY IN USE WITH MY PC'S, WORK INSTEAD?
You will need an expensive dongle if you want to use a wireless network but my KDL EX403 has a socket for a standard ethernet cable. With this connected to the home network I can show a lot (but not all !) the photographs on my computer, and also use it with the iPlayerBeta on this model which seems to work very well. With the correct leads you can also plug a laptop (or other computer) straight in and use the EX403 TV as a monitor.
Also on our TV you can put the pictures on a USB stick and plug that into the USB socket on the TV
I do not know how these facilities vary with the different Bravia models.
No it won't sony dont tell you this. I have just bought one and four days later still can't get it to work . You have been warned !
Many thanks for your response. I don't find anything easy to do with my TV!
Thanks for taking the trouble to reply. I'll try all you suggested.
Just to clarify.
Thanks
I am using an Ethernet cable to connect to my home network and hence to my PC, what details do I need to enter for the server etc .
Hi @bowesie77
Can you please reply back with the model of your TV - as it would help in order to assist you.
Sony seem to want it impossible to show photos on their TV’s unless you use a Sony camera. We had no trouble showing photos and videos on our Panasonic TV
