Just wondered if this model should be able to record on to a USB Memory Stick.
After plugging the first one in the TV told me 16 Gig was too small, so I got a 128 Gig.
The TV registers the stick but wont let me record anything when I press record on the remote.
It keeps asking me if I want to register the device.
Any help would really be appreciated.
Hi @StuartB4, welcome to the Sony Community.
Have a look at this Help Guide article, which has all the info you need. Just remember to format your drive to FAT32.
Mick
Thanks Mick but I've already been through all I can find on the subject.
That's why I thought I'd ask here.
The TV still keeps asking if I want to register the device, even after it's gone through it.
When you say format to Fat 32 do you mean on a PC / Laptop, or should there be an option to do it on the TV?
If it's the former then I will give it a try.
If it's the latter then it's not appearing on the TV.
Thanks again. Will update as soon as I've tried it.
Somehow the TV has ruined the memory stick.
It worked perfectly well in a PC, but after the TV kept trying to register it I can't even access it on a PC anymore.
It shows up on the PC with a removable drive icon and thinks it's a drive with removable media.
If I try to access it to format it windows refuses saying there is no media in the drive.
Looks like I need a new memory stick now.
