when I connect USB mouse to the TV (KDL-42W805A) it works well in the internet browser. But when I connect USB keyboard it is not supported. Why? What can I do to get it worked?
br
Hi there
As far as im aware, USB mice and USB keyboards are not supported. So if it does work, you've got luck on your side.
Now, if that mouse is bluetooth enabled, that might explain why it works. Because according to the imanual : Here
It states :
"Notes
Hi there
It states :
"Notes
