Just got my oled delivered installed yesterday, do they normally turn themselves off if no interaction for a few hours, also have had a couple of times screen goes completely black just for 2/3 seconds then returns to normal. The model is k55xr80pu
Hi @Newtvtv
It appears that your Energy saver is set too low. I have mine set to 24 hours. You should find the settings in System -> Power and energy -> Energy saver -> Turn off TV after. Sorry, I cannot help you with the 2/3 second blanks, you should talk to your Retailer.
@Newtvtv Does the blinking happen with specific content or when using specific input ?
