Hi there
I think I know what you are doing wrong - I am pretty confident that you are plugging the USB Wireless Dongle (UWA-BR100) into the wrong socket.
Below is a picture from the manual. The Wireless Adapter needs to be plugged into the USB Socket - Labeled 2 on the picture:
It should be a nice tight secure fit, and it can only go in one way.
Hope that helps.
Hi there
I have double-checked the specs of your TV. Yes your TV does support the Wireless adapter, as well as you have 1 USB port. Plugging the adapter in, it can only go in one way anyhow. My only conclusion (assuming that the wireless adapter is fully plugged in) is that you have a defective one. I would probably suggest taking it back for an exchange, or even a refund and go the Homeplugs route instead.
Hi there
Hope that helps.
