Hi there
As far as I understand it, no viable solution has been implemented in this. The only thing you can do is either add the recording 'manually' or edit the recording end time after you have added the timer recording in the Title List area.
If I could set the timer through guide and could come back to adjust the end time, it would be more convenient than doing it all manually. However! it does not look like I can change the time on title list screen. I can change the date from the particular date to Everyday; Mon - Sat or Sunday...., but not the time.
