Everything has worked fine up until about a week ago. I can't seem to stream videos from my pc to the tv. Everything checks out ok and reset a number of times. Sometimes the pc can't be seem as an input for videos or music, but can be for pictures???
If I do connect videos are unwatchable due to slow updates and buffering type delays?
Any ideas, nothing has changed, all settings as they were but no video streaming?
Also tried the HOMESTREAM software, everything connects but video buffering makes it unwatchable!!
How are you connecting the device to the Network? Wifi/Ethernet/Homeplug?
Buffering issues are usually down to network issues/traffic or possibly if the Hard Disc of the computer is doing multiple tasks at the same time. Definitely worth rebooting the router ( unplug and leave it off for a couple of minutes to power cycle it).
The fact you have tried different pieces of software all with the same result seems to point to network also, so that would be the first thing to check I think.
Thanks
