I have a Bravia KDL-32S2520 tv. When I autotune it finds the digital channels but will not store them. It will store the channel if I manually tune the channel. This happened after I did a reset when I moved the tv to another room as I wanted to set up the TV again to suit my preferences and this seemed to be the easiest way to start again from scratch . Previously there was no problem in auto tuning and storing. The software is 2.5.504 starter 0.0.30 and I have auto software download on and no new software was downloaded over night as this happened yesterday. Can anyone help? Chris
Hi there
This is a difficult one. If it was me, I'd move the TV back where it was and re-tune the channels in (at least as a test anyhow), as Im assuming you havnt had problems where the TV was originally located.
If this works, I can only assume that its the aerial cabling - whether its the lead from the wall to the TV or the internal aerial cabling.
If it doesnt, I guess we'd have to think of something else, but as manual tuning works, I would guess that is the most logical answer.
