Hi there
The SU-B401S monolithic stand is for the some of the 2011 range of TVs.
You could purchase all the parts for the original stand : HERE, but as you have figured out, its an expensive way of doing things.
Short of re-wall mounting the TV, and as the TV complies with the VESA standard (300x300), have you considered a VESA stand such as :
http://www.amazon.co.uk/MountRight-Table-Top-Stand-Base/dp/B0077ME02S/
http://www.amazon.co.uk/VonHaus-Swivel-Bracket-Suitable-Plasma/dp/B005MWS9V8/
http://www.amazon.co.uk/1home-Cantilever-Bracket-inches-Shelves/dp/B00B77V1CG/
As always, research the product fully before purchasing, to ensure that it suits your needs.
Hi there
Whilst researching another question with the same model TV, I came across the exact model of the 'monolithic' stand that you would like.
SU-40NX1
Getting ahold of one, might be a different story.
Hi there
