Do I need specific glasses to work with my KDL-40HX723 or will any Sony Active glasses work?
Hi cal348,
welcome to Questions & Answers..:smileyhappy:
You can use any of the Sony 3D Active Shutter glasses with your Bravia KDL-40HX723..
You may want to try some on before purchase to compare the fit, etc, see here for more details - Sony 3D Active shutter glasses
Hi cal348,
Hello there
Im assuming that your referring to 3D glasses. Sony 3D glasses for Sony TV's
Models suitable-
TDGBR750
TDGBR250
TDGBR200
PS:Bloody hell, I just looked at the prices on Amazon. They've come down in price a lot.
budget for the 750's they are much nicer, lighter and come with 2 different sized nose bridges for a comfortable fit.
