Hi folks,
I have a Sony BRAVIA KDL-32EX705 and want a fitting soundbar. Sony has the Sony SA32SE1 which supposedly fits 32 inch bravias, but my model is not on the compatible list. Does it fit anyway?
Supposedly I need a device to attach the soundbar to the Bravia. Where on earth do i get it. Cant find it in the sony online shop germany.
Help is appreciated.
tinizong
If you look on the compatible list on the product description for the SA-32SE1 it is only compatible with the 2011 model tv's not the 2010 models like your 32ex705. Therefore you tv will not fit the soundbar.
thanks, but i hoped for a different answer
Hi Dave,
do you know which soundbar fits that model. I have the same problem....
best,
ralf
I have the same TV/problem. Have you found a soundbar that fits yet???
best regards,
Ralf
Hej Sony.
Kan jeg få oplyst om min tv-højtaler er trådløs til blutoue?
Hilsen Jan
Hi Jamili300151,
Could you post your question in English?
- JD
